A-100 van/pickup rears?
EvilScamp
Dalton PA
I have heard that the rears from an A-100 van/pickup is the same with as an A-body,can anybody confirm this to be true?
If it is i found one i can't get fairly cheap!
i dont think they are the same... if i remember i will go measure the one in my a100..
do you know the measurement for the abody 8 3/4??
Mopar 8 3/4" Rear End Dimensions
8 3/4" axle shaft lengths measured from the tip of the splined end to the outside of the flange:
A BODY
'66-'72= 27 11/16"
B BODY
'65-'67= 28 7/8"
'68-'70= 29 3/16"
'71-'74= 30 5/8"
'71-'73 wagon= 31 21/64"
C BODY
'65-'69= 30"
'70-'71= 30 5/8" (Chrysler & Fury)
'70-'73= 31 21/64" (and '69 wagon)
IMPERIAL (Large Bolt Pattern)
'65-'66= 30 1/8"
'67-'69= 30 5/16"
'70-'71= 29"
'72-'73= 31 7/16"
E BODY
'70-'74= 29 31/32"
A100
'65-'70= 30"
D100
'65-'71= 31 1/8"
'72-'74= 31 21/64
Housing widths, flange to flange
A BODY
'66-'72= 52 5/8"
B BODY
'62-'63= 53 1/4" (And '64 Max Wedge)
'64-'67= 54 1/4" (Exc. '64 Max Wedge)
'68-'70= 54 15/16"
'71-'74= 57 7/8"
'71-'73 wagon= 59 7/16"
C BODY
'65-'69= 56 3/4"
'70-'71= 57 7/8" (Chrysler & Fury)
'70-'74= 59 7/16" (and '69 wagon)
IMPERIAL
'65-'66= 57"
'67-'69= 57 3/8"
'70-'71= 54 3/4"
'72-'73= 59 5/8"
E BODY
'70-'74= 56 31/64"
A100
'65-'70= 56 3/4"
D100
'65-'71= 58 5/16"
'72-'74= 59 7/16"
Rear end widths, drum-to-drum:
A BODY
'66-'72= 57 1/8"
B BODY
'62-'63= 58 1/2" (And '64 Max Wedge)
'64-'67= 59 1/2" (Exc. '64 Max Wedge)
'68-'70= 60 1/8"
'71-'74= 63"
'71-'73 wagon= 64 3/8"
C BODY
'65-'69= 61.75"
'70-'71= 63.0" (Chrysler & Fury)
'70-'73= 64 3/8" (and '69 wagon)
IMPERIAL
'65-'66= 61 15/16"
'67-'69= 62 5/16"
'70-'71= 59 3/4"
'72-'73= 64 9/16"
E BODY
'70-'74= 61 5/8"
A100
'65-'70= 61 3/4"
D100
'65-'71= 63 15/16"
'72-'74= 64 3/8"
Spring perch widths (center-to-center)
A BODY
'66-73= 43"
B BODY
'62-'70= 44"
'71-'74= 47.3"
C BODY
'65-'73= 46"
E BODY
'70-'74= 46"
:cheers:
now i dont have to climb under there thanks
:cheers::cheers:
