68cuda
Member
The 302 heads are finally in the machine shop. I'm considering having .020 milled off the block surface of the head. Per the Mopar engine book the intake surface also has to be milled .0095 for each .010 taken off the block mating surface. No problem.
However they also state that the front and rear intake rails of the block need to be milled .0144 for each .010 taken off the head block mating surface.
My question is this: if I have the head milled on both the block and intake surfaces, with the rail surfaces of the block not being milled, will the intake rail gaskets take up the difference? I'm trying to make the heads "plug and play" without modifying the block.
I'm also putting in 360 valves and am concerned about piston to valve clearance. I know this has been done - what's the best way to go about this?
