[SOLD] A body & 340 parts
4 speedin
california
I need a few parts to complete my 68 Valiant build!
1.Original front sway bar for a 68. (Found one)
2.LD340 manifold.
3.Koni shocks.
4.Manual steering box. (tight).
5.Leaf springs.
6.4 speed throttle linkage parts.
7. Coil bracket.
8.68 Valiant driver side tail light. (mint cond)
Thank you! Mike
IF you have lower arms with sway bar tabs and want the factory bar for that reason, I understand, I guess. Any sway bar is better than no sway bar but... the one you've asked for is just slightly better. Its a very long limber timber of a sway bar. Its triangular forward mounts hang too low so bent and/or broken bolt ears there are typical. In my opinion, the least expensive aftermarket bar is a better buy.
Thank you kindly for your advise! I do already have a nice after market sway bar but I just decided to run a stock one for several reasons. I am running torsion bars as well as well as sub frame connectors and torque boxes and koni shocks, So I feel like I don't really need a stiff sway bar as I will be driving mostly on the street for pleasure!
Thanks again, Mike
