sixpakbee
This was pulled from a 1969 383 dodge dart . complet rearend drum to drum. 489 case 3.23 sure grip 4in bolt pattern. Turns freely. This will need to be gone through before you run it.will need new breaks drums turned. The sure grip fills tight with a little back lash like they should. Needs cleaned up very dirty.
Pick up in Sabina ohio.45169
1250.00
1250.00
