I have a reconditioned 8 ¾ housing from a 69 Dart.
All the dirty work has been done on this housing. It was wire brushed down using electric and air tools. The housing was then cleaned thoroughly inside with a large engine bore cleaning brush, solvent and paper towels and blown dry. Two of the housing studs were replaced due to partial stripped threads. Two of the brake line holding tabs were ground off due to corrosion. The housing was then prepped for POR 15 paints by using POR 15 preparation produces Marine Clean and Metal Ready (rust remover and etching solution). It was then treated to two coats of POR 15 and finally two coats of semi-gloss top coat. See some finished and work in process pictures below.
Price is $420 picked up in CT or plus shipping from CT.
PM me any questions.
