[FOR SALE] a body 8 3/4 rearend
moparmafia
I have a complete a body 8 3/4 rearend drum to drum thats still in my 69 barracuda. car is sold. it has 3.23 open third member. asking 800 obo in leitchfield, ky. 42754. I can strap to a pallet and ship thru fastenal for 250 if needed.
Could you give me more info on the rear.
Is it 5 x 4” wheel lug pattern or 5 x 4 ½”
---If it is 5 x 4 ½” I can’t use it so no need to answer the rest of the questions---
Is it the stock rear that came in that car? (was not swapped in at some time)
Has the rear been modified in any way? (narrowed B-body, spring purches moved etc)
When was the last time it was used?
Is it functional without rebuilding? (bearings good, gears good, seals not leaking)
Rust inside and out? (I expect light surface rust on outside where paint has been lost, just want to be sure it is eaten through from road salt etc.)
What is the casting number on the 3rd member.
Can I get the shock plates, U bolts and brake hose to the body with it? (just want it to make sure I get a correct replacement when I install in my dart)
When you say ship through Fastenal I assume I will need to pick it up at a Fastenal near me?
I tried to message you but it says your inbox is full
Thanks Dana
All A-body 8-3/4” read ends are the small bolt pattern 5x4”
Unless someone has put in aftermarket axles and swapped brakes, etc
