I have for sale a basically complete (missing brakes,hardware & drums)
8-3/4 rear end with a 741 - 3.55 Sure-grip * Pulled from a 1970 H-code Dart less then a year ago & stored in a heated garage * Please be mind
full of this when ordering brake lines - as earlier 8-3/4's have a different
Y-block location making wheel cylinder to Y-block different lenght lines *
Also this rear currently uses the larger U-joint & has small bolt axles *
The housing is not rusted & only slightest of pitting - can easily be cleaned
up to show quality * Currently painted semi-black * I did drive the Dart around the shop & the sure-grip worked great - but I never tested it at highway speeds for bearing noise or gear alignment noise * Taking this into
consideration selling price is $750.00 with local pickup only - however if
"YOU" arrange shipping - I will gladly strap it to a pallet & make myself
available for pickup * If you are interested contact Dan 845-473-9300 days 845-546-5523 nights & weekends before 9pm EST * Since I seldom
visit FABO please "NO" private messages - however you can also reach
me at [email protected] for pictures etc. * Located New York 12601
* Thank you & Have a most wonderful day.
