383FormulaS67
Bob
My 67 Barracuda is a 383, with manual steering. Did the power steering gear boxes differ from small block to big block?
I want to install P.S.
It has stock manifolds, but want headers. I've been told: Firm Feel gear box, with TTI headers......Same box, now weather you can fit it is another question. Headers?
I found the answer in my 68 Barracuda. RMS front suspension with a power rack. No torsion bars or box to get in the way. My TTI's fall into place. Mine is a 416 SB, but it would have to make life a whole lot easier even with a Low Deck.It has stock manifolds, but want headers. I've been told: Firm Feel gear box, with TTI headers......
Sadly from all the info and forums I've been reading, it looks like a tight ratio manual box is my best bet..TBD. Thanks All!I put the Borgenson box in with my low deck stroked 400, the 1 3/4 TTI headers hit the box, #3 tube had to be dented. I finally got tired of it and went back to manual steering.
Thanks Roy, I'm liking the set up you have, the Modern K frame takes this car into the 21st century. I want to be able to drive this car on the freeway, fast. I haven't researched availability of the K Frame for a big block??? I'll look into the RMS. Need a second job, first!I found the answer in my 68 Barracuda. RMS front suspension with a power rack. No torsion bars or box to get in the way. My TTI's fall into place. Mine is a 416 SB, but it would have to make life a whole lot easier even with a Low Deck.
Call RMS and talk to Bill the owner. Yes they make it for BB. I was dreading installing the headers, I waited till it was the last thing.TTI 340 step headers, I had the car on a lift and the damn things slid right in! I was amazed. Mine has a power rack. I love it.Thanks Roy, I'm liking the set up you have, the Modern K frame takes this car into the 21st century. I want to be able to drive this car on the freeway, fast. I haven't researched availability of the K Frame for a big block??? I'll look into the RMS. Need a second job, first!
Power rack is nice,.... does the coil suspension do well with bumpy roads? I know your in FL., but Ohio roads are very diverse! Also my inner fenders need repaired/replaced, because of cut out headers. I saw narrowed inner fenders on their website, have you those too??? Thanks!Call RMS and talk to Bill the owner. Yes they make it for BB. I was dreading installing the headers, I waited till it was the last thing.TTI 340 step headers, I had the car on a lift and the damn things slid right in! I was amazed. Mine has a power rack. I love it.
Thanks for the info Mark, first year car pros and cons.The power steering boxes were the same in that vintage, Later years used a larger pitman arm size. K- frame was the same for B engine A bodies and used the same engine mounts (except 440 cars) The 67 K- frame used the cantilevered style idle arm mount, that was the difference, 67 only. 67 Dart/ Barracuda 383 did not have a power steering option availability. The 67 Drivers side exhaust manifold design was the issue that prevented power steering in that year. 68/69 Driver side exhaust manifold for B engine was changed to accommodate power steering. So the 67 driver side manifold is a 1 year only deal.
Mark, I'm finally getting into the restoration on my 67 383. I would like to put factory power steering in. I called Firm feel, and he suggested I call Wildcat Auto wrecking Sandy, OR. They can sell me all parts to convert from manual to power: Gear Box, pump, shaft, brackets and hardware. $500.00 I want the TRW box,but he said a dealer bought all their TRW booxes, all they have left is Saginaw, maybe a Federal. Should I make the effort to find a TRW elsewhere? Is there a quality issue from the three?The power steering boxes were the same in that vintage, Later years used a larger pitman arm size. K- frame was the same for B engine A bodies and used the same engine mounts (except 440 cars) The 67 K- frame used the cantilevered style idle arm mount, that was the difference, 67 only. 67 Dart/ Barracuda 383 did not have a power steering option availability. The 67 Drivers side exhaust manifold design was the issue that prevented power steering in that year. 68/69 Driver side exhaust manifold for B engine was changed to accommodate power steering. So the 67 driver side manifold is a 1 year only deal.
