[FOR SALE] A body Lower control arms
niceolddart
S.E. Pa.
I have 2, left & right side lower control arms from a 74 Duster that I no longer need. I have installed new bushings on the pins, have new bump stops & have not installed the pins yet. (All Moog) This will actually make them easier & cheaper to ship because all will fit in a large USPS flat rate box. I will even include the proper size sleeve to press the pins into the control arms. (Best to do this with a press) I have cleaned up everything, but nothing has been blasted. What you see is what you get. Straight pieces in good shape with NO sway bar tabs.
$250 shipped to you, as long as it's in the USA.
