With a lot of patience and care (And good Tin Snips) you can modify the 1972 and up Standard dashes pretty easily. I did this on my '72 Dart.
BUT BEWARE!! The pinout on the Main Cluster connector IS DIFFERENT!!!!
I had to remove 3 of the pins and relocate them to make the Standard Dash connecter work on the Rallye Dash pins.
You also need to get an Oil Pressure Sender for Gauge, The Idiot Light Sender will not work.
I do have this remap drawn out if anyone needs it.
Later,
Bruce B.
