A-Body Sport Mirrors - Question
ivabiggn
Charlie
Rio Rico, Arizona
I have a question on the A-Body Sport Mirrors.
Aside from the obvious Left and Right thing, is the driver's side mirror and mirror housing the same size and configuration as the passenger side? Please take a look at the photos and tell me if this is a matched set.
That is correct - though the vertical height appears to be quite different in your pictures. The right mirror housing has to be longer or stick out farther because, when adjusted properly, the glass is at a greater angle to the driver. If it wasn't that way, the outer edge of the mirror glass would stick out of the housing.
The vertical dimension of the housing opening should be about 3.5" on each.
