[WANTED] A/C lead firewall to compressor 71’ dart 318
el5dart
memphis, tn.
looking for a oem A/C lead/wire that goes from firewall harness to the air conditioner compressor on a 71’ dart with a 318 v8. i believe it is blue. like to get my A/C going fot the summer.
Thanks!
do you have a photo of what you're looking for?
i have scads of partial harnesses (harnii?) and bits of wire kicking around, if you have something to go off of i can root around and see if i could match it up.
Evans can make you a new one. I believe it also has the wire for the fan in same harness. I had Evans make one for me back in 2008 or so. And yes AC Compressor wire is blue.
Given that wire runs across intake manifold anything old used will be dry rotted and cracked.
