I can tell you from the 64 Valiant side is there is no difference between ac and non ac firewalls. The ac units are not intergrated into the heater. They are under dash condesor units with the high and low pressure lines passing through the firewall. 2 holes and there is a indention the firewall to pilot the holes.
