A/C switch wiring
KJoeZ61
Northampton Pennsylvania
Can someone please tell me if the single blue and green wires are in the correct position on this switch. When I bought the car there was no switch therefore I wasn't sure of the correct positions. The entire heater box and A/C system is being restored.
What year? The AC wiring is documented in the factory manuals in the AC section, not the wiring section..
MyMopar.com....................free manuals
This is 73 model year page 24-45
It's in the 71 Plymouth manual at MyMopar
"Please enter a valid message" WTF!!!! I'll TELL ya!!! This frickin "new" software is so damn much improved nobody can USE IT!!!
Thank you, I guess they are backwards. But if you look at the new picture below the reason I placed them in that position was the way the old cable looks, It appears they were in that position for a long time. Just looking at it the way the wires naturally sit. Thank you for the wiring diagram.
From the wiring diagram, it appears it doesn't matter since those wires go to just a single in-line switch (AC clutch enable). The blower switch gets a separate power feed. But, might as well keep it factory. I usually label all connections w/ a silver Sharpie. You can use alcohol to erase it later.
