Anybody have any pictures of a/c hookup using magnum compressor. Have the kit from Bouchillon and in middle of install. Have a 72 dart. Just thought If somebody had a working system might save me some mistakes.
Just ck'd it is low profile so no problem. Thats good because I already paid to have some fittings welded on the manifold. Did you have a chance to get that radiator hose part#.As I remember the other type rises about 2" above the base. So, you will have to compare.
When I get the hoses made I will post a couple of pictures. Right now about all I have in is a evaporator.Anybody have pictures of ed1946 setup? Some others might want to participate...
No problem, we're suppose to get some of that snow tomorrow.Have not been in my shop since Friday. 6" of snow and another 6" on the way. I will get there at some point. Sorry for the delay.
That helps, thanksHere are a few photos of the top rad hose. I believe this hose came off of the 74 Scamp, Magnum powered, (it is used) that I purchased as a parts car.
I could not find a part # on the hose that is on my car.
Hope these helps.
Some pics where I'm at, still need to crimp hoses.Anybody have pictures of ed1946 setup? Some others might want to participate...
ok thanksAs I remember, you are correct. I used the original wire to activate the compressor.
Also, I have a diagram I will forward that identifies the firewall connections. I will get a photo and forward it to you.
ok thanksI do not have an answer. The a/c guy brought the compressor and manifold and he put it together. Rubber or other washer as seals: Been to long.
Manifold may have had the seals included.
