A Cautionary Tale
Small Block Mopar Engine
  1. jonn6464
    jonn6464 1970 Duster
    500
    340
    Mar 29, 2017
    Weatherford, TX
    Local Time:
    12:13 AM
    I was playing with the timing today on my E-Body, LA 360 engine. I loosened the retaining cover and advanced it, tightened up the retainer and hopped inside.
    Started the car and was listening to the idle when I felt something strange on my gas pedal foot. I was wearing flip flops and it felt like something was crawling on me. I looked down and saw motor oil running down my foot.
    I quickly shut it down and got back under the hood where I saw oil all over the firewall, the valve covers, headers, and pouring down to the floor.
    After some detective work, I realized that the tiny nylon tube that carries oil from the block to the pressure gauge under the dash was split right above the fitting. It was pissing oil everywhere. I must have bumped it with the wrench when I was adjusting the dizzy retainer. I guess the tube was brittle after years of service. So, be careful down there if you have the same set up.
    I pulled the fitting and fed the tube through until the split was gone. It's functioning properly again, but I'm left with a hell of a mess. I wiped down a lot of it, but I need to pressure wash the engine bay.
    There is a question in all of this...
    There is oil on the bulkhead. Can I spray the bulkhead area lightly with degreaser and water? I'll leave it out in the sun all day to dry (it's 100 degrees here so it will dry). Will this do damage to the electrical connections at the bulkhead?
    • Thanks! Thanks! x 1
    • Agree Agree x 1
    • mcodecuda
      mcodecuda Senior Member
      603
      215
      Sep 17, 2007
      Catawba NC Just a little north of Charlotte
      Local Time:
      1:13 AM
      I would change that plastic tubing to copper while you’re at it.
      • Agree Agree x 8
      • kursplat
        kursplat FABO Gold Member FABO Gold Member
        3,456
        2312
        Aug 24, 2010
        so cal
        Local Time:
        10:13 PM
        and this is why i always use steel braided on those. glad you caught it in the driveway. de-grease and rinse. wrap the distributor in plastic so you don't get a bunch of water under the cap
        • Agree Agree x 8
        • krazykuda
          krazykuda Well-Known Member FABO Gold Member How-To Section Editor
          55,084
          20439
          Aug 20, 2007
          Orland Park, IL
          Local Time:
          12:13 AM
          Copper work hardens and cracks with vibration...
          • Agree Agree x 5
          • krazykuda
            55,084
            20439
            Aug 20, 2007
            Orland Park, IL
            Local Time:
            12:13 AM
            I carry a replacement nylon tube kit in my glove box for this reason... It happened to me once... Just once....
            • Like Like x 1
            • Agree Agree x 1
            • 33IMP
              33IMP Well-Known Member
              318
              323
              Jul 3, 2020
              Taxifornia, soon 2b arizona
              Local Time:
              10:13 PM
              I 100% agree with kersplat and krazy. Nylon is illegal for nhra racing, and I don't trust copper either. My car has a.n. fittings and aircraft surplus braided stainless Teflon hose. Not cheap, but I'm race legal, and I won't have to clean my interior.
              • Like Like x 3
              • Agree Agree x 1
              • Phreakish
                Phreakish Well-Known Member
                1,004
                587
                May 28, 2015
                N. Idaho
                Local Time:
                10:13 PM
                A tube of hot, pressurized engine fluid into the cabin always seems insane to me.
                Personally, I'll stick to the electric sending units and gauges.
                • Agree Agree x 2
                • Dana67Dart
                  Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
                  5,135
                  3170
                  Jul 16, 2017
                  Northern Colorado
                  Local Time:
                  11:13 PM
                  That's why I removed the same type of oil pressure guage the day I got my dart
                • Joey4speed
                  Joey4speed FABO Gold Member FABO Gold Member
                  894
                  635
                  Jul 17, 2018
                  Jersey
                  Local Time:
                  1:13 AM
                  John 6464,
                  I use copper tubing, for that very reason. Lucky for you it happened at home.
                  Thanks for bringing it to members attention.
                  Where do you find small diameter steel braided with fittings that small?
                  Joe
                • harrisonm
                  harrisonm Well-Known Member
                  2,795
                  2702
                  Jan 16, 2005
                  Topeka, KS
                  Local Time:
                  6:13 AM
                  Is this an aftermarket oil pressure setup? I don't remember these from the factory. Could you convert to a standard electric gauge with a sending unit? That would seem like a good idea to me.
                  • Agree Agree x 1
                  • kursplat
                    3,456
                    2312
                    Aug 24, 2010
                    so cal
                    Local Time:
                    10:13 PM
                    i go to a hose place close by me and get them made. but you can get everything from summit, by going to the shop i don't need to worry about ordering the wrong fitting for the gauge. they're not all the same
                    senders can go bad, and i like having a mechanical oil gauge. i use a T and keep the dash light too
                    • Hyper_pak
                      Hyper_pak Old School Chrysler Fan
                      2,936
                      2069
                      Feb 14, 2010
                      Desoto Texas
                      Local Time:
                      12:13 AM
                      AN-3 is the size. Aircraft Spruce has a good selection of fittings and such. Important to use Teflon lined braded hose, not rubber braded hose.
                      • Thanks! Thanks! x 2
                      • Like Like x 1
                      • Agree Agree x 1
                      • 33IMP
                        318
                        323
                        Jul 3, 2020
                        Local Time:
                        10:13 PM
                        1/8 pipe female to a.n.3 for the gauge and engine end, with a short male/male 1/8 pipe nipple into the pressure port.
                        • Joey4speed
                          894
                          635
                          Jul 17, 2018
                          Jersey
                          Local Time:
                          1:13 AM
                          Shoutout to Gary from Performace Auto, small shop in PA did just that.
                          He incorporated an oil psi guage face into the standard Oil "idiot light" guage. Brilliant!
                          Looks original, until you look closely.
                          • Like Like x 6
                          • kursplat
                            3,456
                            2312
                            Aug 24, 2010
                            so cal
                            Local Time:
                            10:13 PM
                            nice...
                          • MoparMike1974
                            MoparMike1974 FABO Gold Member FABO Gold Member
                            2,635
                            1864
                            Jun 16, 2017
                            Maryland
                            Local Time:
                            1:13 AM
                            I run copper because of this. I had a 71 duster and the oil pressure line blew inside the car. That car smelled like dirty motor oil from that day forward. The last one I installed I used the fancy braided line. They are pretty cheap and you can get them in just about any length you need.
                          • RustyRatRod
                            RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
                            64,434
                            37379
                            Jun 7, 2010
                            Georgia
                            Local Time:
                            1:13 AM
                            I like good quality electric gauges. That way, you're not transferring fluid to the interior of the car.
                            • Agree Agree x 3
                            • famous bob
                              famous bob mopar misfit
                              17,515
                              6991
                              Aug 14, 2011
                              okla
                              Local Time:
                              12:13 AM
                              Moral of the story , NEVER USE THE NYLON TUBING , ur own fault !
                              • Agree Agree x 2
                              • vitamindart
                                vitamindart Well-Known Member
                                1,229
                                325
                                Jun 11, 2010
                                Vernon,Wisconsin
                                Local Time:
                                12:13 AM
                                I run braided AN line for just that reason. Will probably run an electrical gauge on the next build.
                              • jonn6464
                                500
                                340
                                Mar 29, 2017
                                Weatherford, TX
                                Local Time:
                                12:13 AM
                                Thanks for assigning blame Bob. Very helpful to the overall discussion.
                                • Agree Agree x 3
                                • famous bob
                                  17,515
                                  6991
                                  Aug 14, 2011
                                  okla
                                  Local Time:
                                  12:13 AM
                                  No problem , ''LOL'' , I have always used a copper line , but really like the braided ones , but have never seemed to want to spend the $$ on them at the time I needed it .
                                  • Like Like x 1
                                  • jonn6464
                                    500
                                    340
                                    Mar 29, 2017
                                    Weatherford, TX
                                    Local Time:
                                    12:13 AM
                                    I like the idea of the braided line. But, I'm actually glad I didn't have it this time. If the oil had not sprayed through the hole in the firewall, I would not have felt it on my foot. I was about to take off down the road, and who knows what might have happened.
                                    Anyone know if there are fittings to convert this to an electrical gauge, or do I just need a new one?
                                  • ir3333
                                    ir3333 Well-Known Member
                                    4,704
                                    1245
                                    Jun 1, 2008
                                    ontario,canada
                                    Local Time:
                                    12:13 AM
                                    as others have said.Good quality Stewart Warner electric.
                                  • Wyrmrider
                                    Wyrmrider FABO Gold Member FABO Gold Member
                                    3,611
                                    1724
                                    Sep 5, 2016
                                    los angeles
                                    Local Time:
                                    10:13 PM
                                    soft stainless tube works
                                  • justinp61
                                    justinp61 Well-Known Member
                                    1,682
                                    1075
                                    May 15, 2009
                                    Local Time:
                                    12:13 AM
                                    If you would've had the braided line you wouldn't have had the problem to begin with.
                                    • Agree Agree x 1
