A/F aluminum OD 4 speed 833
PartNDarts
parting some As
Nebraska
Rating - 0%
0   0   0
I pulled the /6 and od 4 speed for my 77 Volare wagon and want to sell the trans. As complete as you need it, from flywheel to tailshaft. Shifter, shift linkage, bellhousing, clutch fork, flywheel, and trans all together or just buy the trans with shifter. Car was a driver and parked because of a siezed brake caliper. I am needing to clean out the garage so if there are no takers, it will probably end up at auction on eBay. Not sure what a fair value is so I'll shoot out $325 complete ($275 for just trans and shifter)and we can go from there. I am in Nebraska (zip 69101) and can box/crate this up and should be able send it either Fedex or UPS. Contact me through PM as I dont get a chance to check the site but every couple days.
need tranny and shifter and linkage I'm in nebraska 68465 [Wilber] 402-989-4225 call if you have time, have cash now. thanks
Put me in line if the other deals fall through. I could probably pick it up. I make trips to Nebraska on a fairly regular basis.
