A great Mopar mystery (at least to me)
Small Block Mopar Engine
  1. 68Dartdude
    68Dartdude Well-Known Member
    48
    1
    Jan 2, 2012
    el dorado hills
    Local Time:
    1:30 AM
    So I wanted to swap out my stock small block LA engine valve covers. The finned ones I had lying around, wouldn't fit under the power brake unit in my 62 Lancer (see virtually no room anywhere). It's an 8" unit. BTW, the breather holes on those are drivers side front, passenger side rear.
    After and extensive search, I saw a pair of Spectre low rider covers that appeared to fit. I talked to the tech and he assured me the photo was a precise representation of the part. Part ordered, part received, uh it was a mirrored photo. It appears that all finned covers have breather holes, passenger side rear, drivers side front. All short, chrome covers have drivers side rear, passenger side front breather holes. I am at a mental impasse, causing more of a brain drain than I'm willing to invest.
    Long story longer, I installed a set of chrome shorts and finally found a 90 degree PCV to fit under the power brake unit. Problem is although it works with engine not running, I wish to drive the car. With engine running above idle, the pressure tips out the PCV valve. It wasn't an exact fit, so I wrapped tape around it and such. PCV into rubber thingy (see brain drain), into valve cover. A good look, but not highly functional. Like some women I've dated.
    So I'm hoping to see or at least hear the burning bush, ah burn. Any advice would be greatly appreciated. Actually maybe those goofy looking stock ones, don't look that goofy after all.
    Thanks in advance.
  2. A56
    A56 MoParAffliction FABO Gold Member
    1,011
    877
    Jun 24, 2014
    White Oak, N.C.
    Local Time:
    2:30 AM
    I'm guessing we don't want to see a picture of the Rube Goldberg.:lol:
    • Like Like x 1
    • Professor Fate
      Professor Fate Push the button, Max...
      714
      904
      Jan 13, 2020
      Wisconsin
      Local Time:
      3:30 AM
      Maybe attack your problem from a different angle. Since '62s weren't designed with a smallblock in mind and space is critical, maybe you could just use the offset master cylinder adapter (Mopar Performance #P5249717) to move the booster/master away from the valve cover, then run any valve cover you want.
      • Like Like x 2
      • 67Dart273
        67Dart273 FABO Gold Member FABO Gold Member
        42,894
        10464
        Oct 14, 2010
        Idaho
        Local Time:
        1:30 AM
        Photos........................might.......................be ....................helpful...............
        • Like Like x 2
        • str12-340
          str12-340 FABO Gold Member FABO Gold Member
          1,025
          554
          Dec 26, 2012
          Vashon, WA
          Local Time:
          1:30 AM
          are you using the bracket that raises the power booster?
        • 68Dartdude
          48
          1
          Jan 2, 2012
          el dorado hills
          Local Time:
          1:30 AM
          Good idea on the adapter piece. Not sure what direction it would move the unit into.
          So here are a few pics. Not much room to go up, or forward. I may move battery/housing a few inches forward away from exhaust manifold. Previous someone looks to have installed a bracket.
          • Thanks! Thanks! x 1
          • Professor Fate
            714
            904
            Jan 13, 2020
            Wisconsin
            Local Time:
            3:30 AM
            I don't currently have any cars with the adapter on them, so I can't say for sure how far the master/booster would get moved over. But if memory serves me (no guarantees there!) it's about an inch- inch and a half... towards the fender. *Looks* like you'll have room. Maybe someone on here can give you a definitive measurement.
          • str12-340
            1,025
            554
            Dec 26, 2012
            Vashon, WA
            Local Time:
            1:30 AM
            I know this is a pain but you may want to get some original valve covers with the breather and the pcv in the middle of the valve cover. Given the car you might try some old power pak valve covers with the finned inserts. The older ones with the two "stove pipes" might still be too high, but the newer ones with a 'modern' pcv grommet should work fine.
            • Agree Agree x 1
            • MOPAROFFICIAL
              MOPAROFFICIAL FABO Gold Member FABO Gold Member
              5,645
              4631
              Jun 1, 2016
              Beach
              Local Time:
              1:30 AM
              Chrome direct connection/MP covers with the part number stamped. Center pcv.
            • kursplat
              kursplat FABO Gold Member FABO Gold Member
              2,599
              1683
              Aug 24, 2010
              so cal
              Local Time:
              1:30 AM
              consider manual brakes...
              • Agree Agree x 1
              • forphorty
                forphorty Well-Known Member
                671
                253
                Jan 19, 2006
                Local Time:
                3:30 AM
                I don't like power brakes myself
              • 68Dartdude
                48
                1
                Jan 2, 2012
                el dorado hills
                Local Time:
                1:30 AM
                Doesn't really need the PB, but it came with it. Not seeing the Direct Connection ones with part number. Seeing ones that are consistent with no goes. Now
                Saw a potential fit today from a one off company, emailed them. We'll see.
                Have the original I could reinstall to go with the chrome one. A new look.
              • famous bob
                famous bob mopar misfit FABO Gold Member
                16,575
                6356
                Aug 14, 2011
                okla
                Local Time:
                3:30 AM
                I dont understand , why didnt u just switch sides ?
              • DesertRat
                DesertRat FABO Gold Member FABO Gold Member
                3,114
                2506
                Jan 22, 2005
                Moses Lake, Washington
                Local Time:
                1:30 AM
                Switching sides also switches ends ------------
              • James Clews
                James Clews Well-Known Member
                61
                59
                Aug 25, 2018
                Australia
                Local Time:
                6:30 PM
                Don't you know how to drill a hole for a a new location?
              • famous bob
                16,575
                6356
                Aug 14, 2011
                okla
                Local Time:
                3:30 AM
                Isnt that the point , to get the pcv and breather/etc. away from the master cyl. ??
              • 69_340_GTS
                69_340_GTS Well-Known Member
                3,901
                1780
                Jul 11, 2014
                Torrington, CT
                Local Time:
                4:30 AM
                I think what he means is that both valve covers are identical, so swapping sides doesn't change anything.
                • Agree Agree x 1
                • DesertRat
                  3,114
                  2506
                  Jan 22, 2005
                  Local Time:
                  1:30 AM
                  Yep that's it. SB valve covers have no right or left but they do have a top and bottom. Switching results in the same configuration - just sign me captain obvious.
                • famous bob
                  16,575
                  6356
                  Aug 14, 2011
                  okla
                  Local Time:
                  3:30 AM
                  AHH , SOOO --------
                • kursplat
                  2,599
                  1683
                  Aug 24, 2010
                  so cal
                  Local Time:
                  1:30 AM
                  must be Aussie valve covers :rolleyes:
                • diymirage
                  diymirage HP@idle > hondaHP@redline
                  19,025
                  12793
                  Oct 12, 2012
                  michigan
                  Local Time:
                  4:30 AM
                • diymirage
                  19,025
                  12793
                  Oct 12, 2012
                  michigan
                  Local Time:
                  4:30 AM
                  this set also has the breather drilled out on the drivers side front
                • 68Dartdude
                  48
                  1
                  Jan 2, 2012
                  el dorado hills
                  Local Time:
                  1:30 AM
                  Some good suggestions here. Thanks. So the thing with finned covers like my Mopar Performance style (black) is they are too tall to insert past the power brake unit since it sits so close to the valve cover and rockers when exposed. Yes can go back to stock but since I purchased two chrome replacement units (3 1/4") tall, I would like to use both, not one. Drivers side does get past PB unit but PCV issue above. May just need to fit the correct super tight PCV, grommet, into valve cover fit.
                • 68Dartdude
                  48
                  1
                  Jan 2, 2012
                  el dorado hills
                  Local Time:
                  1:30 AM
                  Thanks, but too tall.
                • 68Dartdude
                  48
                  1
                  Jan 2, 2012
                  el dorado hills
                  Local Time:
                  1:30 AM
                  There must be a reason why short aftermarket covers are made with this strange consistency...
