1973dusterkid
Watch This
Ok got the new setup and wondering what kind of number you guys think it makes.
Info
71 360
Stock stroke
Std 4in bore
340 J heads 2.02 1.6 valves (milled to 68cc)
stock 340 duel plane intake
Long tube headers 3in collector
flat top pistons 9.2 CR
Howard cam
Cam Style:Hydraulic flat tappet
Basic Operating RPM Range:1,800-5,800
Intake Duration at 050 inch Lift:220
Exhaust Duration at 050 inch Lift:220
Duration at 050 inch Lift:220 int./220 exh.
Advertised Intake Duration:267
Advertised Exhaust Duration:267
Advertised Duration:267 int./267 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.506 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.506 in.
Lobe Separation (degrees):108
Info
71 360
Stock stroke
Std 4in bore
Howard cam
