DartGTDan
'71 Dart GT Fan
My engine will be going "under the knife" soon (double roller timing chain and gears, LD4B intake, 1406 carburetor, & Lokar cables).
While all this is happening I want to replace the water pump. I've found A1 Cardone parts available at SummitRacing (both 6-vane & 8-vane are available). I'd like to have both on hand and replace it with whatever comes off (it's worked well for 40+ years).
Would you use an A1 Cardone water pump? Or, what would you do?
TIA as always!!
:burnout:
TIA as always!!
:burnout:
