[WANTED] A230 3 Speed Input Bearing Retainer
JoesEdge
Downey, CA
The tile says it all. I'm pretty much looking for a 3 Speed (A230) Input Bearing retainer since mine cracked. The size is 4.35 (same as 4 speed but not sure they interchange). I'm in the south Los Angeles area.
they are interchangeable.i only have a 4.80 right now with the small bp.
I think all years will work that the 833 4 speed was in production.the od retainer will not fit tho...bolt circle and outer diameter is too big.
mike bee
Thanks guys! That information is definitely helpful. I called Brewers and that's what Wayne had mentioned, that the 4 speed with the 4.35" bearing retainer is pretty much the same and would work.
