the A500 is the smaler body modern O.D tranny,,,the 518 is the bigger body tranny,,, before u do the A500 look in to the set up for the O.D. see what that takes to hook up,,,i know from dong a 518 and im not sure the A500 is the same,,but,,up to 1992 the O.D is an easier hook up then the 1993 and newer 518,,,al tho its not that big of a deal,,,but a lot of guys that have no clue wil tell you both these trannys are junk,,, if you hook them up correctly they run fine,,
and i agree the keislier O.D auto matic is costly,, and its a GM trany,,,wont find that in my car,,,
i just took out a 518a OUT OF a 1948 dodge street rod we are working on,,other then the over drive unit,, it didnt appear to be as big as a normal 727 body,,
I put a 518 in a A-Body with a 500 Cubic In 968 HP engine and a 8 3/4 4.30 gear.It was on a Street Tire and ran 9.20's and got 14MPG...
The transmissions will both hold a lot of HP and dependable..The MYTH of a 904/500 is what some people THINK..."I" have broken EVERYTHING Including aftermarket "Bulletproof" Housings..
SS
I'm not saying it won't but dollar for dollar, its going to take a lot more modification for the 500 to handle the HP than the 518. All depends on how much money you have to spend.
I seen a site where the guy cut the "fins" off of the tranny and only had to modify the crossmember...i think, does that sound doable?
Hey Larry that motor looks very lonely sitting there all by itself, you should send it down here so I can break it in for you LOL
Bruce
has any one on this site used the gear vender units
Where did the back of the yoke end up? Was it centered in the tunnel or below where it would be with a 727 or 904? For me, the problem would be how low the trans sits, especially with the deeper pan. My 904 in the '69 Swinger is taking a dump now and I have a 518 already to go in it's place, so this thread is just what I need. I have a 440 too on the engine stand, so while I'm at it......the 518 fit in my 75 Sport with zero floorboard mods.
