A727 & A904 Service Manual PDF
MiDi
Active Member
PDX,OR
Please make this a Sticky in Transmission
Here is a non copyrighted Transmission service manual that i have scanned and pdf'd.
I got it down to 18MB so even a guys on slower connection can grab it.
This covers the A727 & A904 for Slant Six and V8.
It also has a extra chapter on torque converters. It's Hosted on my server with a uber fast download.
http://www.datapunx.org/A727 - A904 TECHTRAN MANUAL.pdf
Enjoy! It took me quite a while to scan,edit and encode small enough for download. there is some blurryness in a few of the page edges, i did a high rez version but @ a wopping 50mb + it was to big for the guys with slow connections. this version is usable and @ 18mb even a dialup user can pull it in a hour or so. i also have a bunch of scans of dealer mopar books but most of those are only for 71 thru 74 mopar dart and valiant. anyways i have a pretty large arcive of FSM and other items. anything that does not have a current copyright i will pdf and post on request.
MiDi
Thank you very much for this PDF this is a great find and a lot of work :)
Thanks... I was just about to post a question about my shift linkage leaking, I really hope this will solve my problem, there looks to be enough pages in the manual that if I print them out they will cover and absorb the trans fluid:-D. I hope its only a simple o-ring and not an expensive fix, like a new 5-speed put in place. Ah im rambling, thanks again. Tom
MiDi
Could you please send me a copy of A727 - A904 TECHTRAN MANUAL.pdf. The file isn't out there any more. The high Rez if you can .
Thanks.
nelson
You can download these. First, the info is contained in the Mopar service manuals
See here
http://www.forabodiesonly.com/mopar/showthread.php?p=1970088617
and here
http://www.mymopar.com/index.php?pid=31
and the above site has a trans manual which is essentially just a section out of the full service manual
http://www.mymopar.com/index.php?pid=22
And ALSO from the same site is a whole series of Mopar files and videos
"Master Tech Service Library"
http://www.mymopar.com/index.php?pid=117
Also, there's a GREAT series of videos on Youtube you can get:
[ame="https://www.youtube.com/watch?v=vL8yeBbWPz4"]Rebuilding junk torqueflite 727 part 1 - YouTube[/ame]
and if you have something like a Firefox browser with the "video downloader" add-on you can save those to your hard drive
Also seriously consider buying the book by Munroe:
[ame="http://www.amazon.com/Torqueflite-A-727-Transmission-Handbook-HP1399/dp/1557883998"]Torqueflite A-727 Transmission Handbook HP1399: How to Rebuild or Modify Chrysler's A-727 Torqueflite for All Applications: Carl Munroe: 9781557883995: Amazon.com: Books[/ame]
