Does anyone know if the A745 and the A230 transmissions have the same bolt pattern where they bolt to the bellhousing? Thank you drive through.
The A833 and A230 DO NOT share the same pattern. Although in some cases can use the same bell housing with both patterns present..Swingn’IIRC;the A230 and A833 share the same pattern.
IIRC: the A745, and A903 share a different pattern.
A230s are fully synchronized and can handle street-340s no problem.The A230 has at least two ratios to chose from, that I know of.
As you probably know, the others are not, and while it's not that horrible to downshift into first, it takes a knack for it, and is definitely not for a performance vehicle. Also, the synchronizers are pretty lo-po, with narrow brass rings and such. I have rebuilt many hundreds of them, but, IDK how well they would work or for how long, at higher rpms.
Not much help, I know.
Just a guess here, Rob.Does anyone know if the A745 and the A230 transmissions have the same bolt pattern where they bolt to the bellhousing? Thank you drive through.
