[WANTED] A833
Turbo440Dart
crank runner over-er
Norco Ca
Looking for a decent shape 833 (non OD) for my duster. Slowly gathering parts to convert it from auto. Want something local in SoCal to save on shipping. Got other parts to swap an auto car to manual? Let me know.
Thanks in advance, Chris.
If you can't find it local;
I think I can rustle up almost everything you need, from crank to pinion of an 8.75;
less; the hump, the carpet and the underdash reverse light.
I am currently in the process of reconditioning the V8 box/2.66 low/cast-iron unit.
It Could be had in all aluminum, with a steel-bushing already installed at the front cluster-pin location.
It could be had with an in-line Mr.Gasket shifter.
I also have an overdrive unit.
I also have a stock-width 8.75 drum to drum.
It could be had with any ratio from 2.76 to 3.23, or 4.88s.
Sure-grips too, including, Tuned cone-type Sure-grips. I might even have a spool.
Also available are 340 parts.
I will certainly keep you in the memory bank just incase I can’t find anything local.
I have an a833 64-66 a body ball & trunion
doesn't come with shifter/rods or cross member.
Pick up in Los Angeles area
