[FOR TRADE] A833OD Slant 6 bellhousing
Chained_360
Delusional Member
Indianapolis, IN
Looking to trade my aluminum slant 6 bellhousing for any small block bellhousing. I would prefer aluminum but iron works too. The transmission itself is mid-70's A833 overdrive that was rebuilt in '95 and kept inside with fluid in it and the input shaft greased. Bellhousing also includes the clutch fork and boot (boot is in good shape), but a needs a throwout bearing. The housing is a multiple bolt pattern one, and should marry up to different cases/transmissions.
I'll post pictures later tonight.
