A904 5 clutch plate upgrade
VF69HARDTOP
Australia
Hi guys
I'm looking to order a BIY 904 500hp rebuild kit from Cope Transmission and wanted to know if the 5disc clutch upgrade fits without any mods done to the drum in a 1977 A904?
I've emailed Cope but not getting a reply and as I'm in Australia, the time zone difference makes it hard to ring and speak with John.
Thanks
https://www.coperacingtrans.com/?product=904-biy-500-hp
The kit likely comes with thin .061" grooved red clutches that will fit in a factory 904 4 clutch drum with no additional modifications. You may need a different selective snap ring to get the correct clutch pack clearance.
What clearance should I be looking to set it at?
I see Cope sell a snap ring kit so will order this also.
Typically you shoot for about .012 per friction. Trans brake applications want .060 to .080.
