A904 Trans Oil Pan
340inabbody
Arizona
Hi ok so my leaks maybe due to the pan which is a little beat up. So 3 Questions:
1. What pans have you used and liked?
2. What gasket works best?
3. If you used a deeper pan do you have to lower the filter pickup?
Thanks
1) most name brand aluminum pans work good. Make sure it has a drain plug and even a tapped port for a gauge sending unit.
My choice is TCI. Good looking and affordable.
2)any 904 gasket is good. No silicon (except to just hold on place. A tiny bit too) just don’t over tighten.
3)deeper pan- lower filter. A good pan comes with that adapter and longer screws. Also replace filter at that point.
Joe
Thanks
Hughes makes a nice deep pan, and since youre in AZ you can drive over there and pick one up. Moroso makes a nice reusable one, im running one on a 904 and 727.
Jake
Jake
Are the 727 pans the same as the 904? I didn’t onow Hughes we in AZ. Will look them up.
With a deep pan, the full mark is in the same place. I never lower the filter because I want it up away from the bottom where the particles lay. The pan usually has been blocking the bottom of the filter on most of the 904s I see. Deep pans are just hype. If you want a cooler running trans install a larger cooler. Some of my customers want a deep pan so that's the only reason I sell them. Most cars at stock height shouldn't run a deep pan because it becomes the lowest part on the car and it gets damaged easily. I think some people want a deep pan on a leaky trans so they don't have to watch their fluid level; so of course they do need the filter extension.
Yeah I purchased the Summit deep pan because I wanted a fly cut flat surface to bolt up. Didn’t care if it was more capacity. It looks well made compared to all the stamped steel stuff. So now its a matter of deciding to lower the filter or not. Too bad I no longer have access to a Bridgeport I could of slimed down the extension to half that the thickness which might have been a happy position for the filter...
OK I may have two leaks in the trans. The pan might be leaking but for sure I have another leak. It looks like the area over the trans mount is weeping in the corner see arrow B. It may be the cause of what I see on the two eyelets and bolt (A). It also maybe bolt A not sure. What is bolt A? Could it be leaking or is that go through the case into a wet area? FYI my car's rear end is jacked up so flow would go from the back to the front.
Having issues uploading the right image. Here it the one I was refering to.
There's a lot of air moving around in a lot of different directions under a car. It's very possible that fluid leaked out of the speedo internal lip seal, or possibly thru the cable housing itself; and blew forward onto the access plug. Sometimes the plastic gear gets a groove worn in it, but you can shim the seal outward or just flip it.
Thanks CFH I am doing the inspections passively wiping own and checking with the car up. I believe my leak is from the tail c clip access plate as the trans mount bolts are wet and also around that seal. This is the highest place I see fluid and everything else is wet due to downwind flow so to speak. Unfortunately the transmount is covering it and I have to pull it along with the cross member possible as well.
I see fluid on the outer threads of the speedo. Is there fluid visible inside by the gear stem? Old Car Rule #27 "Always do the easy fix first".
Yes! I changed both gaskets with new ones and it was still weeping. So I pulled it and used a bead of RTV around the lip past the oring. This along with changing my C clip tail acces access under the transmission mount. Used RTV there as well. She looks like no more weeping! I am waiting on my MOPAR gasket you guys mentioned. But this pan I got from Summit is dam nice! No stamped POS.
Both speedometer "gaskets"? One is an o-ring and the other is a lip seal.
Yup both were replaced as well as a shiny new C-clip. Ok what I think is the new outer O-ring was sloppy as Maryjane Rottoncrach. So I inspected the original and it fit better and was in good shape. The RTV was insurance as I don’t want to do that again. Ever.....
Oh and here is the new pan installed in my B-Body. The headers remain the lowest point of the car other than the wheels :)
Also not my welds I could do better....
