abody 8.75 sbp
daredevil
S/w Houston
abody rear housing, axles, backing plates, brakes,shock plates, drums and 742 carrier with 3.23 open. all bolts and hardware. just a set of u bolts,gaskets one e brake cable and the rubber hose junction block needed to install this. pulled apart for inspection,no suprises. pulled out of v8 72 Duster. 700. plus shipping. Will consider Duster hood ,grill for partial trade.
would like to give buyer option of complete rear. if housing sells i will get back to you.
Will sell without carrier for 500.plus shipping. can reassemble. was told it had been rebuilt so i pulled it apart to see. bearings are still full of clean yellow grease. shipping is from 77471
im looking for the shackle set for an a body also the rear brackets that bolts to the frame and the shackles go through the bushings.i think its called an eyelet.let me know if you have something like this and how much.thanks,mike.
