? about magnum swap.
7dart0
peabody,ma
Its probably been beatin to death but can you run a serpentine setup with no a/c and no power steering. also can you use the stock dodge ram alternator and how would it wire up?
tom
I wire it like a regular Chrysler alternator MAD has a wiring diagram or use to to do it It's in a tech archive at Moparts also Never seen the factory stuff used without P/S The A/C uses a idler pulley to replace it
Yes you can. The 2 wires off the Alt. Just get put to the cars stock 2 wires.
You can deate the A/C and the P/S and run a shorter belt. You'll need to re-route the belt over the idler pulley instead of under it to maintain the correct spinning of the W/P as it goes around the crank pulley properly.
