HankRearden
I just installed a new fuel tank and sender with a 3/8 line on my 70 dart. Im planning to use an e2000 pump and an aeromotive bypass regulator to cut the fuel pressure down correctly for the carburetor.
I know that ideally the pump would be mounted below the tank. But as low as the car sits I don't see that as a viable option. Can I mount the e2000 fuel pump above the line coming out of the sending unit? Will it "suck" that far?
