72dds
Member
I have a set of B1BA heads on my 360 and need an accessory hole drilled on the driver side head for my procharger bracket. Does anyone have experience with this? How deep can it be drilled?
In the spot your circle is drawn there is 1.4” depth to the intake coolant passage behind it.I have a set of B1BA heads on my 360 and need an accessory hole drilled on the driver side head for my procharger bracket. Does anyone have experience with this? How deep can it be drilled?View attachment 1716244359
A drill could tell you fasterA sonic checker would tell
You in about five minutes.
