Accessory Power in Engine Compartment?
GupsTateS
Car is a 68 Dart with stock 340 engine. Previous owner installed a fuel pump under the hood, right now power is directly from the battery with a manual switch. Is there an accessory wire somewhere near by I could safely splice into that only goes on when the key is in the run and start position?
Thanks
Sounds good, at least I know that's the way to go. Thanks
