Action City Dragway
superbird6bbl
Terre Haute, In.
Took the Dart to the track yesterday. It was hot and humid. It turned a 7.0129 @ 98.51 off the trailer. It then ran a 7.0001 @ 99.30. I dialed a 6.99 and it went6.9762 @99.76 with a 1.5389 short time on $50 slicks. I then dialed 6.97 and ran another 1.5389 short time at a 6.9550 @ 99.76 mph. I got sent home early, but the car is starting to run. It should run 6.80's when lined out. The timing is at 38 degress. I am going to retard it a couple of degrees next Sat. and try it again.
It should with cooler weather and new slicks. I am running a J converter and I am not sure if I need a modern converter or not.
