Just wondering- has anyone added bronze bushings to as set of un-bushed ductile iron W2 rockers? Mostly I'm wondering if there is enough meat in the casting to ream out for bushings or if the bushed and un-bushed castings are different.
I have no idea now. Used to be under 300 bucks, but I seriously doubt it now. Call him and see. Gary is a super good guy. He can also manipulate the center bore and make them 1.6 ratio if that is of interest as well.Any ideas on the price for that? I'm trying to cost out buying a set that comes without adjusters as well.
..... because....Not sure what spring pressure you are running, but you are weakening the rocker putting bronze bushes in.....
The bushings are bronze, which is a surprisingly tough and strong metal equal to or exceeding cast iron in some properties. So it's not like you are simply boring a bigger hole and thinning the walls out weakening the system. The bushing has inherent strength as well. As mentioned using smaller diameter shafts is another way to increase strength of the rocker if that is a concern.Post #7......because when you make something thinner by removing material [ metal in this case ] ......you weaken it.....
Gzig,
Sadly you are not getting it.....& it is pretty simple. For the second [ or third? ] time, when you remove material from an object, you weaken it. The bush in this instance will do NOTHING to compensate for the loss of strength caused by metal removal. The wrap-around area under the shaft is very heavily loaded & rockers that break often break THERE.......and that is where you are weakening the rocker to install a bush.
You are 100% correct and I agree. However, my friend down under, those millions of engines didn't have squat for spring pressure either. Just something to think about.I imagine the number would be in the millions.......
That is the number of engines of various makes that used ductile iron rockers without being bronze bushed on steel shafts........& provided millions of miles of trouble free service. My Poly engines were among them.....
Post #10 would be the safest way to bush rockers...
Exactly. Plenty of meat for bushings.Just to add to this discussion, here are pictures of said rockers side by side.
W2 Econo on top, W2 bushed bottom
Factory 273 with bushing added by RAS on top, aftermarket 273 (Isky?) unbushed bottom.
I may be mistaken but weren't the original T/A rockers bushed?What you are missing is that rocker was available bushed. Same rocker for the bushing as for the unbushed econo stuff.
And the bushed rockers are for high rpm, high load stuff.
Yes sir they are!And still most of the original used ductile rockers you find are scored on the bottom.
