Adding nitrous have fuel question
swifter
wis
Where do I tap the fuel for the fuel solenoid before or after the regulator??
Thanks Swifter
Thanks Swifter
After the reg., Its also a good idea to set the plate in a pan or bucket, then adjust the PSI threw the plate where you want it.
The best idea hands down is....if it's wet system, plump in a separate complete fuel system for the nitrous. Pump, filter, lines regulator and all. Costs more, but that will assure no lean conditions. It would cost more yet if it leans out. Just sayin.
