adding underdash powerblock...switched and un-switched
megavites
Jackson, NJ
Anyone have a good diagram that lays out how to wire up an accessory powerblock?
I'm adding guages and misc. that I'll need switched and un-switched and I can of need one of those basic diagrams to spell out source power hookup or how to on switched power.
This all would happen under the dash.
Thanks!
Thanks!
Try this website. It may be helpful .
Hot Rod Wiring and How to Do It
There is only one source each of switched and unswitched power so that is where you will have to "get" it.
Switched "ignition run" which is hot ONLY in run feeds the cluster and a couple of things.......warning lights etc, and then out to the engine bay
Switched accessory power comes off the ign switch and feeds down to the buss in the fuse panel which is switched
"Hot" full time power is the OTHER buss in the fuse panel.
You need a service manual. I've posted this a skillion times. Maybe even a squadamillizillion times
Investigate the links below:
Free service manuals
MyMopar - Mopar Forums & Information - MyMopar Tools/Reference
