Adjustable pinion snubber
middleagecrisis
Seguin, TX
I have an adjustable pinion snubber on my 8.75 in my duster. What kind of clearance should I have between the snubber and the floor? The rear leaf springs have five leafs, so they’re pretty stout and I don’t think that wheel hop will be an issue. Obviously, I haven’t driven this car much since I got everything together.This is a street driven car.
I had a friend (RIP) who had a wicked 440 4 speed Challenger back in the 70s and when he went to the track, he preloaded it against the floor. He also welded a piece of 1/4" plate to the floor so it wouldn't beat the snot out of the floor. So the answer is it depends on what you're doin.
I’ve been into Mopars for over forty years and have had several ten second cars. I have never needed a pinion snubber, never. An Abody with the front springs clamped should be all that is required , the quickest 60’ time with SS springs and no pinion snubber is 1.39.
To answer your question, based on your use being similar to mine (high performance street driven 99.5% of the time), with the adjustment holes on the snubber being spaced how they are… pick the adjustment hole that allows you around 3/4” clearance with weight on the suspension. Will it come in to play that way, not really, but it won’t give you weird feedback if you hit a bump that cycles the suspension.
I’m running 6 leaf 340 Heavy Duty Espo leafs out back with a 340 (284/484 cam), a 727, and 3.91 sure grip 8-3/4. I could probably yank the pinion snubber and not notice a difference.
I agree. Even the stock XHD springs won't really give enough on a street car to make the snubber work. The front segments are pretty stout.
Thank you everybody for the feedback. The adjustable pinion snubber came on an eight and three-quarter that I pulled out of a race car. I’ll probably remove it and place a stock piece back on.
When properly adjusted according to the Race Bulletin above, the rear suspension essentially stops compressing except for the rear spring segment resulting in a very stiff ride. Brutal is probably a better word for it.
They are great for launching on a smooth track, but brutal on the open roads. CalTracs are much the same. I just can't take the rough ride they leave you with any more, and had to find other ways to plant the tires on launch.
