moparlee
64 Valiant
Has anybody played with them....I bought one and intend to play with it on my engine run stand. Just curious if anybody has messed with one as far as to see if they help us in anyway/worth messing with.
That's the funniest crap I've read this morning...thanks.Try not to "mess" with things. Learn to do it correctly or leave it alone...
I think I've only ran into one voltage regulator that was truly bad. I say that and I played with the Mopar Performance constant 13.5 deal on my 64 Valiant....I don't know it's been 13 or 14 years ago now....and with hardly any use and it died.There is absolutely no reason to have an adjustable VR. If the battery does not "run" at the correct voltage, fix the cause
No particular order:
1..Number ONE most likely is voltage drop in the harness---or ground--causing the battery to run high, even though the VR setpoint is correct
2...When checking, allow the battery to "normalize" and the engine to warm up--VR is temp sensitive
3...In some cases a bad battery---sulfated, EG
4...In a FEW cases the VR is actually bad--replace it
That's new to me. Never saw one. Thanks for the photos.Not pre 70's stuff.
I do think they sell one that looks pre 70 that is electronic but adjustable also. Heck they're selling some now that will bolt to the alternator and are adjustable also...eliminating the one on the firewall for those that want that....I have luck with Mopar stuff...so the one on the firewall is okey dokey to/for me.That's new to me. Never saw one. Thanks for the photos.
I didn't realize that they even had that I guess....like this?I've forgotten, there is one or two aftermarket 70/ later that are adjustable. "In the day" you could buy a heavy duty truck one that was adjustable for the 69/ earlier grounded field ones. It was square, not rectangular like the older regulator. Standard/ Blue Streak made one.
