OK I was wondering do I have to advance my timing since the clocks do tonight?
Yes you do!OK I was wondering do I have to advance my timing since the clocks do tonight?
PerfectSo clock wise in the northern hemisphere and CCW in the southern right?
How many degrees? Asking for a friend!in the Spring you "spring ahead"..... in the Fall you "fall back" It's all to do with winter fuels
It's 7* this morning.... way to little degrees for the middle of MarchHow many degrees? Asking for a friend!
Mine was close to TDC this morning.It's 7* this morning.... way to little degrees for the middle of March
You got up earlier than me...... most people do. I'm known for the amount of initial I run....Mine was close to TDC this morning.
You guys are falling down on your math!!! An hour of longitude is 15 degrees!!Thought 7 was for a slant. This is for a 426 street rod.
That would explain why in AZ its best to leave timing alone.in the Spring you "spring ahead"..... in the Fall you "fall back" It's all to do with winter fuels
That explains everything! My car came from Albuquerque, so I've been following the Mountain Time Zone all this time. I have so much to learn...That would explain why in AZ its best to leave timing alone.
Yep, just like the toiletsSo clock wise in the northern hemisphere and CCW in the southern right?
Depends if it is digital or not!With a digital ignition does the A mean advanced or after?
Or are they tied to an atomic clock?
