What is the best choice for replacing the OEM sway bar bushings on a 67 barracuda?
Reading some of the other threads, looks like it is a pita to replace the factory style bushing in the original mounting brackets. Dont really want to have to cut the bracket and reweld as some have recommended...nor do I want to drill into the k-frame if I can keep from it. Ideally I'd like to just slap in some new bushings in the old brackets but if that is too hard to do.
Thinking bout trying these...anyone running them.
at http://www.suspension.com/moparcar.htm
This is a picture of the new grease able sway bar bushings and adapter brackets that replace the triangle shaped O.E. bracket and bushings.
This grease able set fits applications: 67-72 "A" body Dart, Demon, Barracuda;
65-69 "B" body Superbee, Roadrunner, etc.
#5.5134 is 7/8" dia.
#5.5135 is 15/16" dia.
$45.00
$45.00
