Aftermarket dampers
Captainkirk
Old School Mopar Warrior
Northern IL
I've seen much fanfare given to the aftermarket dampers out there, (such as FluiDamper, etc). On a street engine, have any of you really noticed a difference? I ran a stock damper last time and had no trouble with it. I could see using one a a super-high revving strip motor, but how much would it really help on a street/strip build?
I think an SFI Damper on a street engine is money better spent somewhere else. Stock should be just fine.
If you were going to regularly spin over 6,000rpm's then that is a different story.
hi, the stock dampner will be ok for 7000 RPM. used one on a 340 stocker for years, turning 7100 RPM in the traps. never moved. fluid dampners are very heavy.
A good balancer will not really "make" more power. But on a street car, it makes the engine live MUCH longer. The "balancer" is really a harmonic dampner. The manufacturers use it to balance the reciprocating assembly because they use cheap materials in the cranks. But it's real job is to remove harmful vibrations from the crank that will normally be produced in a V style engine. Without it, engines will eat themselves. Some race engines run without them because special attention is paid to balancing and materials and parts choices, and the crank is needed to drive things like fuel pumps, blowers, and magnetos. I dont re-use dmapners. I also dont like anything with fluid..Friends had them leak years ago, and I havent found an engineer to explain how fuild can dampen things as good as the right durometer rubber can over a wide rpm range. The best I know of are ATI SuperDampners. I usually use new Professional Products balancers, and verify TDC during every build. They are fairly cheap, coem with the weights if needed, and the rings have never slipped on me. New stock ones have before.
Captain, A stock one will be fine for your street engine. Would highly recomend getting a new one though..I think they were around $100 (Mancini)when we did the 360 in the Duster last summer
The Professional Products ones Moper mentioned should be checked into, may only be a few $ more than a new OEM unit
