Aftermarket flexplate ?
Minnesota
Ive done some research, but I'll ask just to be sure. I have a 360/727 combo and I'm wondering what B&M flexplate I need to run a non-weighted converter with it. Is it the #10236?
Do you know if your 360 is basically stock and still externally balanced? That will make a difference in which flexplate you need
If you have a 360 LA engine 727 transmission that is the correct number
