[WANTED] Aftermarket Magnum heads
EQ has a set of CH318A heads as cast by EQ, offering .227 CFM on intake @500. They reasonably priced and designed for the LA intake manifold, which gives you more options, magnum manifolds selection is limited.
Speedmaster and others have a Chinese knock off Eldebrock Rpm air gap for about $150 that fits LA and magnum
