I have a 69 Dart with a 360, running a Eddy RPM manifold and a 750 Holley. The air cleaner I used as a dropped base 14" K & N 3" cleaner. There as good hood clearance with this combination. Now I am in the process of installing a Fast 2.0 fuel injection unit.
This has changed the position of the air cleaner, I can not run a drop base cleaner, I have to go to a flat base one to clear the fuel fittings.
My question is does the flat base air cleaner with 3" element clear the hood?
