air fuel gauge install thread
younggun2.0
federal way, wa
I have been installing an air/fuel gauge in my dart. It uses a wide band o2 sensor. Here are some pics of the install process.
you have to weld the bung as close to the header as possible. in the top portion of the tube in order to keep moisture from puddling in the sensor.
going to run the wires thru a cover i made for the factory console shift boot hole.
