Air Wolf Engine Masters 408 build
273
Ontario
Engine Masters just did a 408 build with the new Air Wolf heads made 633hp at 6600/6700 and 556lb-ft at 5400 and over 400lb-ft above 3000 with 11.42:1CR and solid roller 262/266 @0.050" 0.672"/0.672".
Heads flow at 0.100 increments
Intake
72/145/219/273/301/312/316/319/321/326
Exhaust
65/108/146/174/205/212/236/238/242/244
Kool thing they flow 301 @ 0.500" lift don't need a massive cam to make em work.
Dam do they look good, but 2000.00 to just over 3000.00, they are pricey.
But they can sure make good power.
That's a perfect cost in the market for the performance level. A set of CNC RPMs - which would be the closest comparison to them in terms of bolt on and running factory stuff - will run all of $3K ready to run, and have similar flow numbers.
I am thinking about a set of these heads..... BUT I would really like to see Edelbrocks new Victor castings before pulling the trigger.
