69valiant21
I remember seeing a thread or post somewhere with the need to remove the plenum between to two bores when using an EFI system. Looking for input from EFI users with airgap intakes. Did you need to notch the plenum? If so how much?
Im running an airgap and will be installing the sniper this spring.
