Alignment on a 65 Barracuda
Bob D
Member
TN
I converted the front brakes to disc. I replace the upper control arm new bushings and new ball joint and new lower control arm /ball joint. I ready to adjust the alignment to be able to drive to a shop for proper alignment. How do I adjust the caster?
Adjust it with the upper control arm mounting eccentric bolts. Caster is the only. Non wearing alignment parameter.
camber and toe will wear your tires.
the first thing to do is get the ride height where you want it. It can change with some driving.
Turn the Upper Control Arm Bolts So Your Upper Arm is All the Way Out in the Front and All the way In in the back.
That will put Your Upper Ball Joint behind the Centerline of your Lower Ball Joint.
