cudajareav
Active Member
Hi all, another electrical issue has come to my attention.
All of my rear lights have quit working, breaks, indicator, running and backup.
the first thing I did was check the fuse (which was bad) and replaced it with a new on. tried the lights, No work.
Checked the fuse again and it was broken. meaning I have a short somewhere?
I have checked to see if there is any exposed wire where I can (by the tail lights, near the plug at the front, and along the bottom of the door, and nothing that I could see that was obvious.
I have an ohms reader, but i'm not exactly sure how to read it and if that is something I need to use to find the solution.
Any information is appreciated.
Thanks in advance!
Thanks in advance!
